- If TOPAZ was installed for a Windows login and for example another person is taking over the TOPAZ duties,
if you now create a new Windows user on the TOPAZ PC for this user,
TOPAZ is not in the registry of this Windows login.
Solution:
- Give full control over the Datatex folder for the new Windows user login created.
Access rights to run TOPAZ under XP and 2000 full control - Thereafter run the reset serial program and re-register TOPAZ.
How do I re-register TOPAZ?
