Which plugin do I use for the SAMSUNG DCS 500i?
Postby Belinda Frick » Wed Dec 01, 2010 8:07 am
Please use the plugin "PSamsungDCS500i.dll", version 2007.02.17.1 or newer.
Available:
On the internet, http://www.datatex.co.za -> Support -> Login -> Topaz -> Plugins -> Samsung.
The plg-samsungdcs500i-update-2007_02_17_1.exe will extract the dll file in the lib folder.
On the TOPAZ CD in the folder PABX3 -> PROFILES -> LIB.
The PSamsungDCS500i.dll needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Please contact support@datatex.co.za for the latest version of the plugin.
See below sample of output data:
    EXT  AUTH TRK  MM/DD STT.TIME DURATION FG DIALED DIGIT       ACCOUNT CODE MCNT     COST CLIP NUMBER  CLIP NAME
    205  5786 702  10/02 10:40:53 00:00:00 O  0215922617                         0     0.00
    205  5786 701  10/02 10:41:07 00:00:06 O  *31*0833045004                     0     0.00
    205  5786 703  10/02 10:42:38 00:00:17 O  0215938553                         0     0.00
    205  5786 702  10/02 10:46:55 00:00:18 O  0215938553                         0     0.00
    206  5786 701  10/02 10:47:35 00:00:00 O  9                                  0     0.00
    205  5786 703  10/02 10:48:17 00:00:00 O  0219332072                         0     0.00
    205  5786 702  10/02 10:48:32 00:00:00 O  0219332072                         0     0.00
    205  5786 701  10/02 10:48:40 00:00:00 O  0219332072                         0     0.00
    205  5786 703  10/02 10:48:49 00:00:55 O  1023                               0     0.00
    205  5786 702  10/02 10:49:59 00:00:00 O  0219332072                         0     0.00
    205  5786 701  10/02 10:52:52 00:00:00 O  *31*0836611035                     0     0.00
    205  5786 703  10/02 10:53:06 00:00:00 O  0219350894                         0     0.00
    205  5786 702  10/02 10:53:39 00:01:01 O  0219021785                         0     0.00
    206  5786 703  10/02 10:54:44 00:00:00 O  *31*0725982219                     0     0.00
ALSO SEE: Samsung iDCS500 Pinlayouts
