Which plugin do I use for the Samsung SKP816?
Postby Belinda Frick » Wed Dec 01, 2010 8:18 am
Please use the "SamsungSKP816.dll", version 2007.02.17.1 or newer.
Available:
On the internet, www.datatex.co.za -> Support -> Login -> Topaz -> Plugins -> Samsung.
The plg-samsungskp816-update-2007_02_17_1.exe will extract the dll file in the lib folder.
On the TOPAZ CD in the folder PABX3 -> PROFILES -> LIB.
The 'PSamsungSKP816.dll' needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Please contact support@datatex.co.za for the latest version of the plugin.
See below sample of output data:
Ext Line Date Time Duration Number
33 6 20/03 10:02:13 00:00:02 1026
28 1 20/03 10:01:33 00:00:47 6991064
28 2 20/03 10:03:16 00:00:45 5348317
31 1 20/03 10:02:58 00:01:46 9505500
33 6 20/03 10:03:11 00:01:58 5575577
22 3 20/03 10:06:49 00:00:40 4109300
21 4 20/03 10:07:01 00:01:14 INCOMING
21 1 20/03 10:08:25 00:00:52 INCOMING
33 4 20/03 10:08:17 00:02:24 TRANSFER
21 1 20/03 10:15:00 00:00:53 INCOMING
22 5 20/03 10:07:45 00:09:05 4109300
33 6 20/03 10:13:45 00:05:39 7108400
33 6 20/03 10:20:17 00:01:44 5924033
33 6 20/03 10:22:23 00:01:26 5575577
21 5 20/03 10:28:06 00:00:11 INCOMING
