Extension barring on the Aristel AV38
Postby Belinda Frick » Wed Dec 01, 2010 8:20 am
Install TOPAZ as you would normally, selecting the new Aristel AV38
Plug-in as your PABX type. Ensure that you are receiving information
from the PABX on the PABX3 - Call Data screen.
Ensure that TOPAZ and PABX3 are always open and running and that TOPAZ
is receiving the data live, to ensure that the budgets can be updated
live and extensions or FAC codes updated.
On Extension side:
Bar Level 8 -> locks the extension/phone
Unbar Level 1 -> unlocks the extension/phone
Please Note: All values excluding one (1) will send a bar command and the
extension/phone will be locked. Only one (1) will unlock the extension.
To reset the bar level:
In TOPAZ, click on Data - Users, click on 'Reset Bar Level'.
To reset all the extensions, click on Setup -> Properties -> Filters and Defaults
and click on 'Reset All'.
When the extension is reset, TOPAZ will send the unlock command to the PABX and the
user will be able to make calls.
