Which plugin do I use for the LG LDK300?
Postby Belinda Frick » Wed Dec 01, 2010 8:30 am
Plugin:
Download and unrar to find the dll file:
PLgLdk300.rar
Upload the dll file: How to update a Plugin
Released: 20090226
It has new code for handling the CLI and can now handle calls with out CLI better.
History:
The Marconi Opticon uses the same PABX3 plugin as the LG LDK300.
The data format of the SMDR seems to be identical and the baudrate is set to 9600.
Use the 'PLgLdk300.dll'file to process the data for this PABX.
Sample of rawdata:
     EXT
12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345
NO   STA   CO  TIME     START          DIALED             ACT  CNT   COST       ACCOUNT CODE
9270 9000  026 00:00:12 29/03/04 08:51 I9000 RING 00:10                                       *
9269 9042  030 00:00:31 29/03/04 08:51 O0333551177          **     0           0
9261 9006  022 00:02:42 29/03/04 08:49 I9006 RING 00:16
9271 9037  029 00:00:00 29/03/04 08:51 O9564805             **     0           0
9268 9009  025 00:02:07 29/03/04 08:50 I9009 RING 00:07
9272 9042  030 00:00:00 29/03/04 08:51 O6973197             **     0           0
9265 9046  023 00:01:56 29/03/04 08:50 t
027 : 0834618499
9270 9013  026 00:02:04 29/03/04 08:51 t
027 : 0834618499 -> 9000
9275 9000  029 00:00:00 29/03/04 08:53 O5952255             **     0           0
NOTE:
  • Duration is in the format 'hh:mm:ss'.
  • Date is in the format 'dd/mm/yy'.
  • Time is in the format 'hh:mm'.
