- Bug: The plugin did not cater for the full international telephone
number, for example 00263123456789 - the leading numbers was not included.
Released: Not released yet
- Bug: The duration was calculated incorrect. The PABX gives it in
seconds which must be converted to hh:mm:ss.
- The Ericsson MX1 server can be programmed to have the same
- Trunk/Line:
This is needed:- when trunk recording is used (need trunk/line to tie recording to call details) or
- for trunk utilization reporting or
- costing per trunk/line (routers, etc.)The trunk/line is not present on internal and transferred calls.
- Telephone number on transfer or pickup call.
This will also influence costing (outgoing transfer).
- Extension on pickup call.
This will influence monitoring of extension. - Code: Select all
20090130 1002 00000 CJ 2642 2731 0 15 2642
20090130 1002 00021 J 2684 45 0 6 2684
20090130 1002 00017 M 0 706 0118369201 2651 0 0 001001001 00118369201
20090130 1002 00003 NJ 2633 45 0 0 2891
20090130 1003 00303 M 0 706 0313144000 2614 0 0 001001001 00313144000
20090130 1003 00014 J 2684 45 0 4 2684
20090130 1003 00000 CO 0 710 0833049401 2633 2633 0 34 005001006 00833049401
20090130 1003 00032 J 2622 2667 0 4 2622
20080212 1055 00020 FJ 9 2127 0 0 45
20080212 1056 00000 CJ 2128 45 0 0 2128
20080212 1056 00404 I 2093 0313031838 0 2 001001011 2093
20080212 1056 00013 J 2123 45 0 3 2123
20080212 1056 00055 T 45 0 0 001001017 45
20080212 1056 00000 CJ 2064 45 0 0 2064
20080212 1056 00141 I 2042 0 14 001001019 2042
20080212 1056 00016 FI 2000 0116149772 5 0 001001020 45
20080212 1056 00000 CO 0 61 0114322000 2002 0 59 001001022 00114322000
20080212 1056 00005 A 2064 0116149772 0 0 001001020 2064
20090326 1808 00024 M 0 700 1026 8706 0 0 001001016 01026
20090326 1810 00016 M 0 701 0832336614 8706 0 10 002001021 00832336614
certified output as the MD110 and MX1.
An Ericsson certified technician needs to do this. If the certified
format is in place you can use the standard MD110 Plugin.
See:Example of rawdata for Ericsson MD110 when using the certified plugin
If you are using the default output of the Ericsson MX one
server, then you will need the plugin 'PEricssonMX1_Server.dll'
- version 2009.2.3.1 or newer.
Please note: The default output is not a certified format.
The default output does not provide all the call details required, for example:
Sample of rawdata:
Program String:
-format "{currentTime year 0R 4 4}{currentTime month 0R 2 2}{currentTime day
0R 2 2} {stoptime md110time L 4 4} {duration md110duration L 5 5}
{conditionCode2Character L 4 4}{accesscode1 L 3 3}{accessCode2 L 3 3}
{dialedNumber R 16 16} {callingNumber L 16 16} {accountCode R 10 10}
{cilCode L 6 6} {opQueTime R 2 2} {ringTimeCounter L 3 3} {ogTrnkID R 9
9}{incTrnkID R 9 9} {connectedNumber R 16 16};{newline};"
Options to get SMDR data:
Setup the linux PABX to write out an output file to a Windows location.
Setup TNG to read the file in as input.
The PABX has a serial port, which is also the programming port. Some support companies connect a modem to it for remote maintenance, which means this option is not available for SMDR.
You can use the Datatex Linker program to collect data from
the MX1 server and then collect it with TOPAZ/TNG, see forum post
How do I install the Linker service?.
