TOPAZ PABX3 Plugin: Nortel Opt 11C rev2
Postby Belinda Frick » Wed Dec 01, 2010 9:01 am
Updated release: not released yet
The Call record 'B' is abandonded calls. These calls are either
incoming unanswered or internal unanswered.
B 113 00 ATTN02 2632 08/06 10:03:41
& 000 000
& B
Some of these calls were marked as outgoing with telephone number as O_UNKNOWN.
History:
Plugin name: PMeridian_Opt11C_Rev2.dll
Example of rawdata:
Outgoing call from ext 8220 to 0112373112 on trunk 6 member 16
N 019 00 8220    A006016 06/10 10:44:39 00:03:32.0 A00112373112
&        000 000
&                                   000
Incomming call from 0123283435 to ext 8090
N 030 00 A006034 8090    06/10 10:48:06 00:00:44.0
&0123283435XXXXXX                            8090XXX                         000 000
&00:04                                000 01 0
Outgoing Call from 8166 to 083644594 on TRunk A007009
Transfered to external trunk A006043
S 127 00 8166    A007009 06/10 10:55:19 00:00:04.0 A0083644594
&                                                    033.0.00.03             000 000
&                                     000
E 035 00 A006043 A007009 06/10 10:57:29 00:02:06.0
&        000 000
S 000 00 8166    A006043 06/10 10:54:07 00:01:16.0 A00215961019#
&                                     000
&        000 000
&                                     000
Internal Call to ATT from 8630
L 036 00 8630    ATTN02  06/10 10:57:35 00:00:08.0
&        000 000
&00:02
Programming:
Data Block: CDR (Call Detail Recording)
Prompt Response Comment
REQ: CHG Change existing data block
TYPE: CDR_DATA Call Detail Recording
CUST xx Customer number
CDR (NO) YES Change Call Detail Recording data
- IMPH (NO) YES CDR for Incoming Packet data call
- OMPH (NO) YES CDR for Outgoing Packet data call
- AXID (NO) YES Auxiliary Identification output in CDR record
- TRCR (NO) YES Carriage Return sent after each CDR message
- CDPR (NO) YES Coordinated Dialing Plan Record option
- ECDR (NO) YES End-to-End Signaling digits in CDR record
- BDI (YES) NO Buffer Data Interface for CDR
- OTCR (NO) YES CDR provided, based on Originally dialed Trunk Route
- PORT 0-15 CDR port
- - CNI a...a Calling Number Identification (a...a = (DGTS), CLID, or NONE)
- BCAP (NO) YES Bearer Capability in CDR
CHLN (0)-23 Charge account number Length
FCAF (NO) YES Forced Charge Account active
- CHMN (1)-CHLN Minimum number of digits for FCA code (Entry can be equal to
or
less than response to prompt CHLN)
- FCNC 0-99 FCA Network Class of Service
