Required:
First you need the RESET Program.
It is available on the:
- On the TOPAZ CD it is in the EXTRAS folder it should be called something similar to "Topaz.ResetSerial.Install.exe" depending on your cd version.
You can run this from the CD.
If you have an older TOPAZ CD, the program will be "reset.exe".
This file needs to be run from C:\Program Files\Datatex\Topaz\Data\ . - Download, unrar:
You need to do the reset serial logged into Windows with the
user login of the person who will be using TOPAZ.
- Close TOPAZ.
- Log into Windows with the TOPAZ user login.
- Run the reset program.
Click INSTALL,
then ACCEPT
and NO TO ALL.
Click on Reset,
then Close. - Open TOPAZ.
[SETUP -> PROPERTIES -> LISCENCE]
There must be a serial number, else the reset serial did not work.
