Topaz is not displaying the correct cost for a call
Postby John Richard Procter » Thu Jun 23, 2011 11:52 am
Topaz is not displaying the correct cost for a call. It is using local call rates.
First check that you did a "Load Rates".
  1. To load the rates, click on "Setup -> Properties -> Rates",
  2. If you are in Botswana or Swaziland then "do NOT add local area prefix..."
    must be ticked, else leave it blank.
  3. Enter your area code
  4. and then click on the "Load Rates" button.
  5. Now select your Zone file. The files must be in
    C:\Program Files\Datatex\Topaz\Rates".
    If you cannot select the file from this directory, copy
    it from the CD into this directory! On the Topaz CD
    you will find the zone files in the RATES folder.
    Choose your country folder, then ZONE.
  6. Click on Open.
    Once the "Load Rates" are completed you will get an
    message "Load Rates Successfull". Click on OK.
    To test if this is working use:
  7. "Check Cost" or
  8. In TOPAZ -> RATES -> Standards, enter the prefix,
    click on test. (when using a number in the test section
    ensure that it is at least 6 digits long)
    If this fails, then the Prefix X-Ref table may
    be damaged, to fix this:
  9. Run Re-index How do I reindex a Database File? OR
    Rebuild How do I Rebuild my whole data directory?
  10. or download a rates update from our website.
    Also See:
    Topaz shows some area codes as local, when the number is a national number.
    If the above has been done and the rates still
    show local, then you must purge the calls and import
    them again:
  11. In Topaz > SETUP > PROPERTIES > TRANSACTIONS > Purge Prior To
    Enter the date and click on Yes. Remember it will
    purge all the data before and including this date.
    Therefore make sure you have the pip files to
    import it again.
  12. Now, import the pip files for the period
    you did the purge.
How do I import extra PIP files into Topaz?
