Make sure that the path that is shared on the master PC is shared with
write access to you.
If you have Read-only access you can't create some of the
necessary files to start the client. This is why an error is generated.
If windows 2000 or XP is used, the share needs to give your account
access to the share as well.
Also read: error that the path is controlled by another .NET file.
