The Samsung NX308 plugin doesn't show account / pin / authorisation codes
On all Topaz CDs written before August 2002, the default plugin doesn't show
account codes.
You can enable the account codes by going to "Options, Filepaths" on the PABX3
interface. Click on the "Configure" button. The Account code field starts at
position 75, and has a length of 4.
The better option is to install the DLL written specifically for the NX308 as
described below.
On the Topaz CDs written after March 2002, the DLL is available, but is not used
by default. It can be found under PABX3\Profiles\lib\PSamsungNX308.dll.
You can also download it from our web site at http://www.datatex.co.za.
To configure the PABX3 interface to use the DLL, copy it to
"C:\Program Files\Datatex\Pabx3\profiles\lib". Go to "Options, FilePaths" on the
PABX3 interface. Click on the "open folder" button to the right of the PABX DLL
path. Select the PSamsungNX308.dll file and click on the "Open" button.
