cellphone calls are in the "other" column on the Call Type
Postby John Richard Procter » Mon Jun 27, 2011 7:31 pm
My cellphone calls are in the "other" column on the Call Type Report.
Topaz shows cellphone calls made on the normal phone line in the Cellphone Category.
The cellphone calls made thru a cellrouter will show in the Other Category.
To check this do a report per trunk line for the cell routers and compare it with
your report per Call Category.
Also See: Report of cellphones numbers dialed on trunk lines.
