How to setup the Export Facility
Postby John Richard Procter » Mon Jun 27, 2011 7:51 pm
How to setup the Export Facility for use with Jade Property Management System (PMS) Or Roommaster
Required:
This document assumes that a working Topaz is already installed on site.
Enable the export facility:
  1. Click on [Setup -> Properties -> Network and Front Office].
    Tick the enable.
Configuration of the export facility:
  1. Select STANDARD as your export format.
  2. The Export Path and filename can be changed as well.
    The Default location and file name of the export Filename.
    C:\TMPTOPAZ\TPZFO.TXT
  3. You can select either the COST or Billing PRICE to be exported.
  4. Now click on [DATA -> Extensions].
    Find all the extenions that you want to export for JADE / Roommaster
    and tick the BILLING tick Box
Sample string:
ext   number                   price          date        time
T:238   0845863621               3.82           17-08-2005  08:32:22
