When I run the Reset Serial program
Postby John Richard Procter » Mon Jun 27, 2011 8:23 pm
When I run the Reset Serial program I get an "insufficient diskspace" error
You need to free some diskspace in order to
run this program and for TOPAZ to run smoothly.
Please see: PC requirements to run Topaz
Right-click on your local drive and choose
Properties. There is a "Disk Cleanup" option
where you can delete unneccesary files.
Also try deleting the TMPTopaz folder:
C:\TMPTOPAZ\
Please consult your IT department for more
information on freeing up diskspace or
extending memory for your PC.
Only then can you continue using TOPAZ.
