I want to setup all my data for the client before I go
Postby John Richard Procter » Tue Jul 12, 2011 3:23 pm
I want to setup all my data for the client before I go and do the installation.
At your office:
  1. Install TOPAZ on your PC.
  2. Enter all the company and user data.
    When entering the company detail be sure to click on the tick to save the data.
At the client:
  1. Install Topaz.
    nsert the Topaz 1.6.0.0. CD. Select Topaz from the menu.
    It will give you the option to check the PC.
    Click on Install.
    Choose the correct Country and area code.
    The zone will be in your telephone directory.
  2. Close Topaz.
    Copy the directory "C:/Program Files/Datatex/Topaz/Data" from your PC
    to the PC of the client to the directory "C:/Program Files/Datatex/Topaz/Data".
  3. While Topaz is still closed.
    Run the reset program.
    Then open Topaz and do the re-registration.
Read SSL:"How do I re-register Topaz"
