Required:
- TDA plugin version "2005.11.8.2" or newer.
[www.datatex.co.za -> member area -> login -> topaz -> plugins]
Call Data Example 1: Verify Codes
- Code: Select all
Date Time Ext CO Dial Number Ring Duration Acc code CD
05/07/04 11:38AM *2241 04 6244587 00:01'39
05/07/04 11:38AM 233 03 0406779935-C 00:04'07 TR
27/07/04 04:16PM *195 04 0860111055322D 00:03'39
27/07/04 04:16PM 101 01 <I> 0'03 00:00'15
In this example "*2241" is the verify code, which we use as the account code,
and "233" is the extension.
Call Data Example 2: Account Codes
- Code: Select all
14/07/05 10:26 143 32 0724477653 00:01'39 5302
14/07/05 10:27 300 21 <I> RC
14/07/05 10:27 500 21 <I> 0'06 00:00'00
14/07/05 10:27 138 31 0722241321 00:05'52 0722
In this example we use the value in the account code column as the
account code, else if there is a number starting with a "*" in the
extension column, the extension value is used.
Call Data Example 3: Account Codes & Verify Codes
- Code: Select all
05/07/04 11:38AM *2241 04 6244587 00:01'39 523
In this example if the account code column has a value it will be used
as the account code, even if the extension field has a value starting
with "*".
