Basic Setup instructions for the SMSManager
Postby John Richard Procter » Tue Aug 30, 2011 12:14 pm
Basic Setup instructions for the SMSManager (SmsRouter & GsmModem) [OLD VERSION]
Please remember that this is applicable
to version 1.0.
  1. Save the SMSManager.abc attachment.
    Rename the "abc" to "exe".
  2. Double-click op the icon,"Accept".
    > It'll install to "C:\Program Files\Datatex\SMSManager."
    > Copy this SMSManager folder to a directory on your network.
  3. Double-click on the GSMModem exe.
    On the taskbar will be a green icon.
    Right-click on it; Show.
  4. Click on "Tools" & choose "Configure Modem" & "Re-connect".
  5. On the right hand side of your screen you
    will see whether a connection was established or not.
    There should be information beneath the headings
    "GSM Device" etc. The BUSY colour should be green.
    In die Base path specify the locations on your network:
    > \\yournetworkname\SMSManager\SMSBase
  6. Open CallMonitor. Choose SETUP. Insert PC name
    in the "SMS Router Host" option where the Modem Software
    is running (thus the PC with the Modem connection)
    The port is 25005.
  7. Run SMSRouter exe.
    On the Setup tab choose the filepaths:
    > Incoming: \\yournetworkname\SMSManager\SMSBase\inbox\
    > Outgoing: \\yournetworkname\SMSManager\SMSBase\outbox\
    > Sent: \\yournetworkname\SMSManager\SMSBase\sentbox\
    > Temporary: \\yournetworkname\SMSManager\SMSBase\tmp\
    > Topaz: \\yournetworkname\SMSManager\SMSBase\topaz\
  8. Also on the Setup tab (Settings section):
    TOPAZ IP: where your Master TOPAZ is installed
    TOPAZ Port: should be 25000 (?)
    Local Port: should be 25003 (?)
NOTE: The GSMMODEM's "Exit" & "Close" options does not
kill the program (only hides the form). So if you want to
kill it - open Task Manager (ctrl, alt, del) & "End Process".
