Not all my calls show/missing data on report
Postby Belinda Frick » Thu Feb 02, 2012 12:01 pm
When I pull my reports, not all my calls are listed. Looks like there are missing data.
This can happen if for example the database is damaged, please try the following:
  • Close TOPAZ and all Client TOPAZ programs that might be open on the network.
  • Navigate to the C drive.
    You will see a folder named 'tmptopaz'.
    Delete this tempory folder.
    Go to the folder 'C:\Program Files\datatex\Topaz\'.
    Rename the 'OldPabxPIP' to for example 'oldpabxpip' followed by the date.
  • Now do a DBRepare on the database folder. See:
    How do I do a DBRepaire?
  • Once completed, pull the same report again.
If still incomplete data, check the rawdata files if calls were captured for the missing time period.
