My cost does not show on the TOPAZ report
Postby Belinda Frick » Wed Mar 28, 2012 11:18 am
  • To ensure that your database is not corrupted, please do a DBRepaire as suggested in the forum post:
    Not all my calls show/missing data on report
  • If this does not resolve the issue, do a report on the ENQUIERY screen.
    TOPAZ -> ENQUIERY, select the date range and View. If the duration column shows zero here then the PABX did not send off a duration for this call. TOPAZ only reports on what the PABX sends off.
  • To ensure that rates are loaded and updated to your calls.
    • Load Rates:
      Open TOPAZ.
      Go to Setup -> Properties -> Rates ->Load rates, a window will appear, select your zone and click on open.
    • Re-cost your calls:
      Open TOPAZ.
      Go to Setup -> Properties -> Rates ->Re-cost calls, select the date from.
      Pull the report again to check if you cost shows.
    • How do I test a rate in TOPAZ?
    If your call now cost correct under Test Cost Calculator then you can pull the report. The costing should be correct.
  • Why are my outgoing calls not being costed in TOPAZ?
  • If your report still shows no cost and the call details get a cost under 'Test Cost Calculator', the only option is to blank the TOPAZ database and re-load the rawdata or pip files, see forum posts:
