Which plugin do I use for the LG GDK 162?
Postby Belinda Frick » Tue May 08, 2012 5:07 pm
Plugin:
Download and unrar to find dll file:
plg162.rar
Upload the dll file: How to update a Plugin
Example of rawdata for LG GDK 162:
[13:06]E5805:UCD-DND
0484 CO15  31  01:04 23/03/01 13:11  O
0485  259  15  01:04 23/03/01 13:11  I259 RING 00:08
0486 5803  16  00:59 23/03/01 13:12  I800 RING 00:11
8444  100  04  00:37 12/08/03 14:11  O71558496           **                     P001
~1=167=42=9=10=129=155=0=0=0
~11=5=5=0=18=0=0=0=0=0
0487 5803  31  00:33 23/03/01 13:17  I5803 RING 00:08
0488 5811  28  00:51 23/03/01 13:17  O0833101186         **
NOTE:
  • Entries starting with '~' and '[' is ACD data and not SMDR for your Telephone Management System.
  • Duration is in the format 'mm:ss'.
  • Date is in the format 'dd/mm/yy'.
  • Time is in the format 'hh:mm'.
NOTE: If you logged rawdata and it is in the required output format, then you have the option to re-import it after you loaded the correct plugin: See forum post - How do I import rawdata into TNG?
