Where do I find the TOPAZ install files?
Postby Belinda Frick » Thu May 31, 2012 12:07 pm
TOPAZ has been discontinued.
We do not provide the install files anymore.
You can use:
  • Your TOPAZ install CD.
  • Some technicians copied the install CD on the TOPAZ PC, please check.
  • If you have have a backup of the Datatex folder or TOPAZ installed on your PC, you can use the datatex folder instead of the install - see re-install/move forum post below.
For alternatives see:
