TOPAZ PABX3 Plugin: Telumat Time Versatility101
Postby Belinda Frick » Thu Sep 06, 2012 11:45 am
  • This plugin was written for:
    • the Telumat Time Versatility101
    • using system software version 204
    • See sample of rawdata below for output format.
  • Please use plugin, 'PTelumat_Time_Versatility101_Ss204.dll'. Version '2007.03.09.1' or newer.
    Available:
    • Download and unrar:
      PTelumat_Time_Versatility101_Ss204-version-2007_03_09_1.rar
      Upload the dll file: How to update a Plugin
    • On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
      The PTelumat_Time_Versatility101_Ss204.dll needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
  • Sample of rawdata
    Field position ruler:
    12345678901234567890123456789012345678901234567890123456789012345678901234567890
    Rawdata:
    O/G      01/01/05 13:56:14 00:00:13 L01 E20   E20      0000.00      0137574002
    O/G      02/01/05 09:36:27 00:00:28 L01 E20   E21      0000.00  002 0137574002
    I/C      02/01/05 09:38:21 00:00:10 L01 E20   E20      0000.00
    I/C      02/01/05 09:38:49 00:00:25 L01 E20   E21      0000.00
    O/G      02/01/05 09:39:55 00:00:17 L01 E21   E21      0000.00  001 0137574002
    O/G      04/05/09 16:26:30 00:00:03 L08 E234  E234     0000.00  016 0780793405
    O/G      04/05/09 16:24:18 00:02:32 L06 E219  E219     0000.00      0333453236
  • Please note that this format:
    • it does not supply CLI for incoming calls.
    • for incoming transferred calls the extension transferred to is the telephone number.
    • For the Telumat Time Versatility the Pin Code is represented by the index number. Please link to the user name. You will find the pin code on position 65 and it is the next 3 digits.
      • In TNG this is the Pin Code.
      • In TOPAZ this Pin code is represented by the account code [DATA -> ACCOUNT].
      A pin code is used to identify the caller.
    • For TNG, the account code is on position 5 and it is the next 4 digits.
      An account code is an code entered into the phone to represent calls made on behalf of the client/department.
  • Action codes:
    This plugin only has action codes for:
      answered
      unanswered
      transferred
