Configuration for PANASONIC VB 9 output
Postby Belinda Frick » Mon Sep 10, 2012 11:23 am
COMMUNICATIONS SETUP
BAUD RATE       [4800]
PARITY          [None]
DATA LENGHT     [8]
STOP BITS       [2]
USE DTR         [Yes]
USE RTS         [Yes]
REQUIRE CTS     [No]
REQUIRE DSR     [No]
USE DTR         [Yes]
SOFTWARE RX     [No]
SOFTWARE TX     [No]
SOFTWARE RX+TX  [No]
XON CHAR        [17]
XOFF CHAR       [19]
PABX SETUP
Delimited Fields [No]
Field delimiter [,]
Fieldname             Start   Length   Field Other
Date                    [12]     [5]      [] Format [# dm]
Time                    [18]     [5]      [] Format []
Extension                [3]     [2]      []
Number                  [35]    [15]      [] Strip Leading Non Numerics [No] Strip all after first non numeric [Yes]
Incoming                [33]     [1]      [] True [I] Default []
Account                  [0]     [0]      []
Hours                   [24]     [2]      []
Minutes                 [27]     [2]      []
Seconds                 [30]     [2]      []
Line/Carrier             [8]     [2]      []
Action                   [0]     [0]      []
Pulses                   [0]     [0]      []
Decimal duration         [0]     [0]      [] Use Decimal Duration [No]
Accept at position      [35]                 Accept Lines with [ 0123456789]
