Configuration for PANASONIC KXTD1232
Postby Belinda Frick » Wed Oct 03, 2012 11:55 am
PABX SETUP
Delimited Fields [No]
Field delimiter []
Fieldname             Start   Length   Field Other
Date                     [1]     [8]      [] Format [#/dmy]
Time                    [10]     [7]      [] Format []
Extension               [20]     [3]      []
Number                  [27]    [15]      [] Strip Leading Non Numerics [No] Strip all after first non numeric [Yes]
Incoming                [27]    [10]      [] True [] Default []
Account                 [67]     [4]      []
Hours                   [58]     [2]      []
Minutes                 [61]     [2]      []
Seconds                 [64]     [2]      []
Line/Carrier            [24]     [2]      []
Action                  [78]     [2]      []
Pulses                   [0]     [0]      []
Decimal duration         [0]     [0]      [] Use Decimal Duration [No]
Accept at position      [27]                 Accept Lines with [0123456789<]
