When Topaz is started up, it will wait about 1 to 2 minutes and then will it check
if there is a data file from the PABX interface with call data. If there is one,
it will import the calls automatically.
If it could not find the file or if Topaz is not running in master mode. It will
not be updated. If the timer is switched off it will not update either.
The PABX.PIP file can be manually imported from the
Setup -> Properties -> PABX Data screen. There is a "Import Now" Button that you
can used to specify a PIP file to import.( this can also be used to re-import
old data that might have been lost.
