Configuration for Teleboss 2000
COMMUNICATIONS SETUP
BAUD RATE [4800]
PARITY [None]
DATA LENGHT [8]
STOP BITS [2]
USE DTR [Yes]
USE RTS [Yes]
REQUIRE CTS [No]
REQUIRE DSR [No]
USE DTR [Yes]
SOFTWARE RX [No]
SOFTWARE TX [No]
SOFTWARE RX+TX [No]
XON CHAR [17]
XOFF CHAR [19]
PABX SETUP
Delimited Fields [No]
Field delimiter []
Fieldname Start Length Field Other
Date [36] [9] [] Format [@dd-mmm-yy]
Time [46] [8] [] Format [#:hms]
Extension [2] [3] []
Number [14] [17] [] Strip Leading Non Numerics [No] Strip all after first non numeric [No]
Incoming [14] [1] [] True [] Default []
Account [66] [5] []
Hours [56] [2] []
Minutes [59] [2] []
Seconds [62] [2] []
Line/Carrier [11] [1] []
Action [0] [0] []
Pulses [0] [0] []
Decimal duration [0] [0] [] Use Decimal Duration [No]
Accept at position [14] Accept Lines with [ 1234567890]
