How do I configure the HARRIS
Postby Belinda Frick » Fri Nov 19, 2010 11:46 am
Configuration for HARRIS
PABX SETUP
Delimited Fields [Yes]
Field delimiter []
Fieldname Start Length Field Other
Date [1] [0] [4] Format [#ymd]
Time [1] [0] [6] Format [@hhmmss]
Extension [1] [0] [8] Swap with Line on Outgoing [No] Swap with Number on Incoming [Yes]
Number [1] [0] [13] Strip Leading Non Numerics [No] Strip all after first non numeric [Yes]
Incoming [1] [0] [2] True [001] Default []
Account [1] [0] []
Hours [1] [0] []
Minutes [1] [0] []
Seconds [1] [0] []
Line/Carrier [1] [0] [9,12]
Action [1] [0] []
Pulses [1] [0] []
Decimal duration [1] [0] [] Use Decimal Duration [No]
Accept at position [8] Accept Lines with [12]
CLI [1] [0] [14] CLI seperate from normal number [Yes]
Time2 [1] [0] [7] Format [@hhmmss] Calc Time2 - Time1 [Yes]
Please note that the field delimiter is blank not a space
You will need version 2000.1.0.63 or higher for this configuration to work.
