How do I configure the Miracall PABX
Postby Belinda Frick » Fri Nov 19, 2010 11:52 am
Configuration for MIRICALL
PABX SETUP
Delimited Fields [No]
Field delimiter []
Fieldname Start Length Field Other
Date [35] [8] [] Format [#-dmy]
Time [44] [8] [] Format [#:hm]
Extension [2] [3] [] Swap with Line on Outgoing [No] Swap with Number on Incoming [No]
Number [14] [16] [] Strip Leading Non Numerics [No] Strip all after first non numeric [Yes]
Incoming [14] [16] [] True [] Default [INCOMING]
Account [65] [5] []
Hours [55] [2] []
Minutes [58] [2] []
Seconds [61] [2] []
Line/Carrier [10] [2] []
Action [7] [1] []
Pulses [0] [0] []
Decimal duration [0] [0] [] Use Decimal Duration [No]
Accept at position [2] Accept Lines with [0123456789]
CLI [] [] [] CLI seperate from normal number [No]
Time2 [] [] [] Format [] Calc Time2 - Time1 [No]
