by Belinda Frick » Fri Nov 19, 2010 11:53 am
- Make sure that Topaz is CLOSED on all PC's(including the client PCs)
- Go to the C drive and delete the 'tmptopaz' folder.
- Make sure that you make a backup of your data folder before using this utility. The data folder is usually "C:/Program Files/Datatex/Topaz/Data".
Check if the program re-index.exe is :
- on your TOPAZ PC:
in C:\Program Files\Datatex\Topaz\Data\
This program will re-index your Database Files. (re-index.exe) - or (Start >> Programs >> Datatex Gems >> Tools >> ReIndex)
- Else, you will find the program:
on our Website (http://www.datatex.co.za -> member area -> login -> topaz) - or on the TOPAZ CD in the EXTRAS folder:
re-index.zip
It must be stored in the same folder as your Topaz Data Files.
C:\Program Files\Datatex\Topaz\Data\re-index.exe
Once you have this program in your data folder, run the re-index it.
On the program window, click on the "By Directory" Button.
Select the file that needs to be re-indexed and click "Ok".
(e.g. Master.db or Tran.db)
Now Click on Rebuild. You should see the progress bars move as it
rebuilds and re-indexes your data.
Once everything is done, the program should report at the bottom of
the window if it was successful.
(The program will require a tutil32.dll that is included by default.)
ALSO SEE: The re-index of the Topaz database does not seem to work.
