1. Close the PABX3 program. Shut it down.
2. Make sure it is not running
3. Copy the new plugin PSomething.dll into the directory
C:\Program Files\Datatex\pabx3\profiles\lib
4. Restart your PABX3 program.
This can be done via Start->Programs->Startup->PABX3 or from your
Windows Explorer.
If you had "Create Raw Data" set to on. You will see a tick under
Tools you can re-import your pabx data by clicking on
"Load Raw Data" under the tools menu.
This will re-import your data and now use the new Plug-In
