Date Issue with panasonic KXTD1232
Postby Belinda Frick » Fri Nov 19, 2010 11:58 am
The Panasonic KXTD 1232 does swap the day and the month around on some months.
This is a hardware issue that we can not fix, but our PABX interface does have a
workaround for it. In other words, we do get the date correctly.
To check if this has happend to you:
  • Take the current month you are in, e.g. June (6th month)
    Now take the dates (04-06-2001) The 4th of June 2001, check if you have data
    for that day by using the enquerries.
  • Click on Enquirries, Select Day, then Select the date (4th of June). Now Click on
    query. Verify that you have data for that day.
  • Do the same for the 7th of June and the 12th of June. If you have data for this
    time period, then there is something else that could be wrong.
  • Now if you take the dates that you used and swap the month and day as follows:
    04-06-2001 -> 06-04-2001 (6th of April)
    07-06-2001 -> 06-07-2001 (6th of July)
    12-06-2001 -> 06-12-2001 (6th of December)
    and do the same query on the data for these dates, you should find data.
    If this is the case, you need a PABX Interface update.
