This is a Windows related feature. Topaz uses the format that is currently set
for Windows. To change it do the following:
Open your windows CONTROL PANEL, then click on REGIONAL SETTINGS.
Set it to English (South-Africa)
Now click on the DATE
you should see your date format looking something like this:
mm/dd/yy or yy/dd/mm
you need to change this to the format you would like to see:
dd/mm/yyyy
This will show 25/06/2001 for instance.
Key:
dd = day
mm = month
yy = year (2 DIGIT)
yyyy = year (4 DIGIT)
Also See: "Field "Maan" not found or error in updating rawdata".
Also See: Windows 95 Regional Settings Problems
