This is a Windows related feature. Topaz uses the format that is currently set
for Windows. To change it do the following:
Open your windows CONTROL PANEL, then click on REGIONAL SETTINGS.
Now click on the CURRENCY
You can change your currency Symbol there.
Also See: Windows 95 Regional Settings Problems
Once your settings has been saved in Windows.
Close TOPAZ and open it again.
