Call Monitor Configuration from Ver 2000.1.4.12
Postby Belinda Frick » Fri Nov 19, 2010 12:19 pm
The CallMonitor.ini file is a normal text file and can be modified with
a text editor like Notepad.exe.
This file is in C:\Program Files\Datatex\CallMonitor\
COMMENTS
1. Limited knowledge of networking and TCPIP is required.
2. In all instances 0 means false and 1 means true.
e.g. SHOWCLI=1 means that CLI popup will be shown.
3. See default settings at the end of this document.
Definitions
[NETWORK]
TOPAZIP The ip address of the PC running TOPAZ.
TOPAZPORT The port where TOPAZ is listening on.
LISTENPORT The port where CALLMONITOR is listening on.
[GENERAL]
USERID This identifies this user of CALLMONITOR.
Important for faxing
SHOWCLI Screen pops will show if CTI/CLI is available
ASKREFERENCE Forced reference screen pops enabled
REFERENCEPATH The path to the reference list lookup file.
This is a text file that can be shared
accross a network.
[FAX]
SERVER The IP address of the PC where the fax modem is installed
FAXLIST The path to the faxlist lookup file. This is a text file
that can be shared accross a network.
[RECORD]
TRIGGER Trigger level for noise activated recording
AUTOSTART Automatic recording on or off
STOP Idle seconds (no sound) before auto stop of recording
PATH Path where voice files are saved
AUTOSAVE Will create and save voice files automatically
WRAPUP Time to complete making notes before going into the next auto
recording mode.
Defaults
[NETWORK]
TOPAZIP=127.0.0.1
TOPAZPORT=25000
LISTENPORT=25003
[GENERAL]
USERID=A Topaz User
SHOWCLI=1
ASKREFERENCE=1
REFERENCEPATH=reference.lst
[FAX]
SERVER=127.0.0.1
FAXLIST=C:\Program Files\Datatex\CallMonitor\FAX.lst
[RECORD]
TRIGGER=76
AUTOSTART=0
STOP=10
PATH=C:\Program Files\Datatex\CallMonitor\Voice\
AUTOSAVE=0
WRAPUP=20
