My reporting is running very slow
Postby Belinda Frick » Mon Nov 22, 2010 1:33 pm
It has been reported that if a network printer is used
and the network connection to the printer is lost, the
actual previews will take long to display. This means
that after the processing of the red bar at the bottom
of the screen it still takes long to display.
Make sure your network connection to your network printer
is up and running correctly.
The smaller the database size, the quicker it can read the
database. If you cannot archive the data with TOPAZ Centre, please
switch the 'TIMER OFF' while running the reporting.
Remember to switch the TIMER ON after reporting is completed.
