What is new in PABX3 version 3.3.0.0
Postby Belinda Frick » Mon Nov 22, 2010 1:34 pm
A new feature is available that allows you to discard any call data lines
where the number is less than a specified number of characters.
e.g. discard all calls where the number is less than 6 characters.
This will help to filter out partial dialed numbers.
To setup this facility go to Options->General and look for
Discard Calls where the number is less than ? digits long (0=ignore)
Min value=0
Max value=9
Note
1. You could lose calls that are costed e.g. 1026=local call.
2. You can recover from lost calls if the Tools->Create Raw Data
option was selected prior to the filter option being used. Change the
minimum length to either 0 or a new length and use the
Tools->Load Raw Data facility to re-load the data.
Remember TOPAZ will handle all duplicate entries in the pipe
files correctly!
3. Topaz already filters out any calls where the number is less than 3 characters
long.
