How do I select a new plugin in PABX3?
Postby Belinda Frick » Mon Nov 22, 2010 1:39 pm
First, if you are updating an existing plugin you must close the PABX3 interface.
The Plugin can either be in PSomething.EXE form or in PSomething.DLL.
PSomething.EXE is a Self Extracting Archive. This means that it is a
compressed file that will extract the plugin to the correct location. Just
run this file. After accepting the license, the install screen will be presented.
The default extract path is [C:\Program Files\Datatex\Pabx3\Profiles\Lib]
Click on Install. If this is an update of an exsiting plugin, you will be prompted
to overwrite the file.
PSomething.DLL is a Plugin file. This is what the files look like on the CD.
This file has to be copied into the /Profile/Lib folder in the PABX3 folder.
Once the plugin is installed in the correct place, the PABX3 interface can be
started again. Click on Options -> FilePath. Click on the button
next to the Pabx DLL and select the new file that you have just installed.
Now once you click on Save it will load the new plugin and start using it.
