Well it is finally here, the new release of Topaz. 1.5.0.7
The long awaited reference reports, Budget email facility and of course the
cancel button for those long reports.
Here are the new features:
1. A cancel button to stop the long reports.(e.g. Departmental Analysis)
Minimize any report that is on the screen and click on the Cancel button
to close and stop the report.
2. Reference Report (Summary All reference codes)
3. Reference Report (Detail report like enquire, after selecting one reference.)
4. Reference Report (Detail report like enquire, for all Reference codes)
5. E-Mail when budget limit is reached.(Each User has a E-Mail address where the
mail can be sent to.)
6. Report on Budgets (Budget Amount, Available and Used) (Standard Report)
This report will list all the users and what their current budgets are.
Here are some changes that have been made to Topaz:
1. Summary with Detail: This report format will now display the extension
and Username on each call. (When a report is generated per extension and
account codes are being used, the account code's user name can be seen
on each call. In other words, you can see who phoned on each extension).
2. Column width of "Number of cell calls" on Call Category Report has been made
wider to display larger number of calls.
3. Checked the rest of the columns of Call Category report and made some
other columns wider as well.
4. More detailed logging to the log file. (If you have errors, check your
Log file, the cause should be listed there.)
5. "Do Not List" can only be changed when logged in as Admin.(For more
security)
6. Account code Listing in Account order and in User Order.
7. Duration of total calls on "Standard Vs Routing" in HH:MM:SS
(Seconds displayed as well)
8. On the Data maintenance screen, the lookups tab has been moved from the
bottom of the screen to the top. (Many people didn't see it at the bottom
of the screen.)
9. On the billing screen the "Show cost to Date" will now preview the printout.
10. Invoice display times with the date and the room location.
11. Display budget amounts with 2 decimal positions only.
12. Telephone number must be at least 10 charaters long on the Company
details screen.
The following issues have been corrected:
1. Enquiries report, sometimes printed "QRLabel14" in the middle of the
first and second detail lines.
2. Removed the error that came up after registering Topaz if it had
previously expired.
3. Removed the error that came up after deleting records with
"Purge Prior To".
4. Fixed an issue with printing Standard Reports not clearing memory
efficiently.
5. Fixed a bug that would reset the dates on the standard report screen
every time you would run a report.
6. Departmental analysis was not printing in Department order.
(was printing in Name/Ext order)
7. The standard reports did not work correctly after running a
detailed "Custom Report"(Date separator issue)
8. Custom destination shows on Total Vs. Avg Report.
9. Create the Line file on upgrade of version older than 1.5.0.0
10. Billing screen - Date format issue when saving.
11. Query screen date format fixed. (Must always be MM/DD/YYYY)
