Print report by extension with reference codes
Postby Belinda Frick » Mon Nov 22, 2010 1:44 pm
Try one of the following:
TOPAZ -> REPORTS-> STANDARD REPORTS:
To update reference codes: Click on UPDATE REF.
Now select reference code from the SELECT A REFERENCE TO VIEW drop down box.
And select if report by price or cost from REPORT COST OR PRICE.
Do the normal settings for STANDARD REPORTS
(From Date & To Date & Route)
Now click on either Reference Details or Reference Summary for your report.
TOPAZ -> REPORTS-> CUSTOM REPORTS:
For this option you need to setup a report for each reference code.
Click on the "+", now enter your report heading under Description.
Report options : Summary
Select records : All
Summary Report Formats : Detail with Summary
Order by : Group
Group by : Extension
Maximum Records : 0 (for all records)
Field Selection : Reference = (Enter the reference code)
Save your report with the tick mark.
Remember : The Description field may not be blank.
