What is new in Topaz 1.5.0.11
Postby Belinda Frick » Mon Nov 22, 2010 1:56 pm
New
1. Export the Database to PIP file with a reference code.
2. Import the PIP files with an additional field for reference codes.
3. Added the extention to the email that is sent out when someone is barred.
4. Added a new Rate code TelkomD for additional rate codes (Swaziland)
5. Display the company name in the Title bar of Topaz. (Easier to see which
Topaz is open)
Issues Resolved
1. Will only send one email now, when it initially bars the extension.
2. "Booking out" on the billing screen caused some systems to give an error.
3. Database made more reliable.
4. Detail with summary report, the name printed over the numbers if the
name was to long.
5. If your username was longer than 30 chars, it would not print
correctly on the Detail with summary report;
