I am using account codes, and the user names do not appear
Postby Belinda Frick » Mon Nov 22, 2010 2:55 pm
  1. Make sure that you have "Use account codes" checked on the
    "Setup -> Properties -> Filters & Defaults" screen.
    Make that the account code has a user associated with it.
    If it does, you may have to do an "Update TRX" (on the Data screen) to
    update the user details. Update TRX will only update the TRAN file with the new
    data if the fields on the TRAN file are blank.
  2. When using account codes, the account codes are associated with the user and not the
    extension. The extension must have no details linked to it.
    Also See:
    Topaz Report by Account Code.
    Topaz Report by extension for Incoming Calls by Account Code
  3. Your database indexes may be damaged, and Topaz is unable to find the
    appropriate records, even though you can maintain them. Do a re-index of the
    database.
    Also See: How do I reindex a database file? for help on re-indexing the database.
