What's new in topaz 1.6.0.1
Postby Belinda Frick » Mon Nov 22, 2010 3:26 pm
New
Add network settings for Call Guard.
Add Call Guard setting to Budgeting facilities.
"Reset All" now looks at the CG Budget Type to decide what to reset.
(Accounts or Extensions)
When this option is looking at Account, the account codes that are
blocked, will be sent to Call guard. Call Gaurd will do the barring.
Issues Resolved
"Reset All" Didn't bar someone that has a negative BudgetAmount.
"Reset Bar level" didn't bar on negative BudgetAmounts.
Enquiries report: Made the Number field a bit wider for international numbers.
