I want to install Topaz using the internet downloads
Postby Belinda Frick » Tue Nov 23, 2010 2:19 pm
Go to www.datatex.co.za choose Downloads.
Go to the Topaz Section.
You will need the following:
Download "Topaz Install Disk 1 to 6" for the Topaz base installation.
Then to upgrade to the latest Topaz Version download "Topaz Base Update Version ..."
Then for the latest rates update download "Topaz Rates For South-Africa for ..."
Installation:
Now do the normal installation.
Also See: How do I install Topaz from the disk download.
Do the rates update:
Do not open Topaz.
Run the upgrade.
Run the rates update.
Open Topaz.
Remember to do a Load Rates.
In Topaz go to [SETUP -> PROPERTIES -> RATES ->]
Make sure you selected the correct Dial Code and Zone. Click on Load Rates.
For a country other than South-Africa just download the Rates for that country if available.
