Log entry in ONYXLines:
Version [1.0.3.0]Digital,45 : EVT_OFFHOOK,EVT_CC_CALL_CONNECTED
[2008-01-17 14:12:51] Version [1.0.3.0]RecordTo: MTRecFileAsync
(\\172.19.1.178\Program Files\Datatex\Onyx\work\045_076B5071449C45.gsm):
(E0002210 on channel 45)
In this case the problems was caused by the ONYXLines.ini file. The
settings in the file is correct, but it seems like the location where
it was written on the harddrive is faulty. We renamed this ini file
and then stopped and started the ONYXLines service. It created ini
again. Thereafter recordings took place again.
