- Go to the playback tab
Enter the correct search options to retrieve the recording and right-click on it.
Click on the triangle to listen to your recording.
You can rewind, forward and stop the recording at any time.
You can adjust the volume while listening to the recording.
Listen across network:
- If you have an ONYX with a tap, you can use it as a supervisor from another PC
on the network to search and listen to recordings. For each PC you want to listen from
you will need an ONYX (the tap is the license to run it).
Also see: I want to listen to my recordings on another PC, they must be in wav.
Also see: Does ONYXPlus have access control?
