ONYXPlus backup options
Postby Belinda Frick » Mon Dec 13, 2010 11:33 am
How are backup's configured?
Click on the backup tab under the settings tick enable backup
Backup time-> select the time the backup must run.
Number of days between-> the backup will run every X number of days.
Incremental backups
This will have the date of the backup as the name.
It will backup the entire database each day.
Note:If this box is untick it will overwrite every backup with a
new one, in other words every time the backup is scheduled it will
override the previous backup.
Where are my recordings saved?
By default all recordings are saved in the ONYX folder.
You can save it to a different location in the destination path.
Please note:
The backup is made of the database and not the recordings. If you require
backup of the recordings you need to make a backup of the data folder.
The recordings will be in the folder for each day.
There is no purge option.
