You can setup a security password on the playback screen to prevent any unauthorized access
to recordings in ONYXPLUS.
Click on the settings tab in ONYXPLUS.
If it is the first time a password is being enabled, leave the 'old password' section blank.
Only enter your password in the 'New' and 'Confirm' password fields.
If you wish to disable the password, enter your password in the 'Old Password' section only
leaving the other fields blank.
Remember to click on the 'Apply changes' tab to save your settings.
Now that your password has been saved, each and every time you access the playback screen and settings screen
you will be prompted for the password. Enter your password and click 'OK' to access the recordings.
