Required:
ONYXPlus, version 1.0.1.0 or newer.
www.datatex.co.za -> SUPPORT -> LOGON -> onyxplus
ONYX, version 1.2.1.0 or newer.
www.datatex.co.za -> SUPPORT -> LOGON-> onyx
You need to enable the ONYX standalone to integrate with the ONYXPlus.
All recordings made by ONYX will be updated to ONYXPlus.
Please note:
This is valid from all recordings made after the 'Enable ONYX + connection' option was ticked.
Configuration:
In ONYX under SETTINGS (for each instance of ONYX):
Tick "Enable ONYX + connection".
Enter the extension number for this workstation.
The WORKPATH and DATAPATH has default file locations. You can
change these locations for the local paths in ONYX under SETTINGS.
Example of an ONYX.INI file
[RECORD]
WORKPATH=C:\Program Files\Datatex\Onyx\work\
DATAPATH=C:\Program Files\Datatex\Onyx\Data\
