ONYXPLUS Card solution: default ini files
Postby Belinda Frick » Mon Dec 13, 2010 11:39 am
When ONYXPlus is installed, it creates the OnyxConfig.ini. Once the
PC is rebooted to finalise the installation, the Onyx_Sweeper.ini
and the OnyxLines.ini is created. All these files contain default
settings.
There is no need to change any of these settings!
Setup:
Access:
the Windows user has full control over the Datatex folder and
that the Datatex folder and sub-folders is not read-only.
the ports 27002, 27004, 27005 must be reserved for ONYXPlus.
use the PC name as part of the database path in Onyx_Sweeper.ini:
In this example ONYXPC is the PC name of the server that ONYXPLUS
is installed on:
DATABASE=ONYXPC:C:\Program Files\Datatex\Onyx\ONYX.FDB
Examples of default ini files:
OnyxConfig.ini:
[CONFIG]
BROADCAST=
GUID=[Your unique number here. Do not change this value]
INILOCATION=C:\Program Files\Datatex\Onyx\OnyxConfig.ini
Onyx_Sweeper.ini:
[PATHS]
DATAPATH=C:\Program Files\Datatex\Onyx\data\
WORKPATH=C:\Program Files\Datatex\Onyx\temp\
DATABASE=C:\Program Files\Datatex\Onyx\ONYX.FDB
[PORTS]
LISTENPORT=27004
Please note:
The WORKPATH should be as follows:
WORKPATH=C:\Program Files\Datatex\Onyx\work\
In this folder the onyxlines creates the dt2 files for the sweeper.
The DATABASE path should use the PC name as noted below.
DATABASE=ONYXPLUS:C:\Program Files\Datatex\Onyx\ONYX.FDB
In this example the PC ONYXPlus is installed on has the PC name ONYXPLUS.
The ONYX folder must be shared. Use the network paths. Therefore the file path must be:
[PATHS]
DATAPATH=\\ONYXPlus\Onyx\data\
WORKPATH=\\ONYXPlus\Onyx\temp\
DATABASE=ONYXPlus:C:\Program Files\Datatex\Onyx\ONYX.FDB
OnyxLines.ini:
[NETWORK]
LOCALUDPPORT=27002
CLASSC=000
[CONFIG]
WRITELOG=0
MIN_LENGTH=2
Note:
The OnyxConfig.ini does not display the setting
'CONFIG_LISTEN=27005', but this default value is loaded.
See full default settings below:
OnyxLines.ini:
[CONFIG]
BROADCAST=
MIN_LENGTH=2
CONFIG_LISTEN=27005
[NETWORK]
LOCALUDPPORT=27002
