ONYXPLUS open error: 10065 No route to host
Postby Belinda Frick » Mon Dec 13, 2010 11:43 am
XP: If the PC is disconnected from the network, it will
disable the network functions.
Standalone ONYXPLUS:
If your ONYXPLUS is not on a network, follow the steps below:
Adding a loopback network connection under Windows XP
In the sweeper.ini change the Database path to use the
local network ip.
[PATHS]
DATABASE=127.0.0.1:C:\Program Files\Datatex\Onyx\ONYX.FDB
